jtr1962
I've been riding a mid-1980s vintage Raleigh since the early 1990s. The bike has served me well to date. About two and a half years ago I upgraded to a 10-speed STI system, and also added aero wheels and airless tires. Everything still works well after 4700 miles. My reason for starting this thread is I've come to the realization that the frame won't last forever. It has a fair amount of rust on it, despite the fact that I never ride in the rain. Perhaps this winter I'll strip it down and paint it. Nevertheless, I'm sure ~25,000 NYC miles have taken their toll on the frame. The frame broke near the right rear dropout about 12 years ago. My adhoc repair, which is basically using a steel plate to hold things together, has worked well ever since. Should failures occur in more stressed areas, they would be beyond my capability to repair.
I'm at the point then of considering preemptively replacing the frame before some critical failure occurs. Of the four common frame materials, I'm leaning heavily towards titanium. Here's my rationale when comparing the pros and cons:
1) Steel-probably the best all around frame material in terms of cost and performance. The primary drawback is rust, especially in places with wet, humid conditions such as NYC. In general I beat on bikes, so eventually paint will chip, and the frame will rust.
2) Aluminum-lighter than steel, impervious to rust, can be made into aero shapes. The biggest downside for me is the limited fatigue life of aluminum. Sure, aluminum frames are overengineered to account for this. Nevertheless, in a place like NYC where smooth roads are the exception, I would be very concerned riding anything with a limited fatigue life.
3) Carbon-light, aero, doesn't rust. I wouldn't even consider a carbon frame on account of the poor condition of the streets here, plus the typical sudden failure mode of carbon fiber. The bike might seem fine after hitting a huge pothole, such as the ~12" deep monster I hit at 22 mph back in April (surprisingly, I didn't fall, and my wheels weren't damaged). Later on, however, microfractures might suddenly cause catastrophic failure.
4) Titanium-similar characteristics to steel, unlimited fatigue life, impervious to rust, lighter than steel. Only drawback is the initial cost, although it seems titanium frames can sometimes be had on eBay for $300 to $400.
OK, I've more or less settled on titanium unless someone thinks there's a good reason not to. I do have some questions:
1) I'm 5' 9", and my PBH (pubic bone height) is about 86 cm. What size frame would be appropriate? This is a road bike, and I'll be using 700c wheels and 700x20 airless tires.
2) Are there any makes/models to avoid? On the flip side, which are the best brands?
3) It seems most titanium frames come with a carbon fork. To me it seems the front fork is the very last place you would want to use carbon. Any frames with titanium forks?
4) Any aero titanium frames? This to me would be the best of all worlds.
5) Should I go with oversized tubes? I'm a fairly strong rider (~200 watts output average over an hour) and frame flex might be a concern.
Obviously, given my rather precarious financial state, I'd like to spend as little as possible. And there's no hurry. I'll probably be able to get at least a few more years out of the Raleigh while I'm waiting for a good value.
Here's the Raleigh as it is now ( weight with everything as shown is about 28.5 pounds and yes, the frame is a little large for my height ):
