i am testing a prototype of such a charger. very nice!
So called hobby chargers tend to allow for this sort of flexibility, but typically are limited to charging single cylindrical cells at a time. You can create a parallel charging rig out of a cell holder.
A drop-in charger with the ability to set termination current or target voltage, with on-board LCD live read out, would be sweet.
So there really isnt any option for a drop in ready to go charger that can do this?
You're probably talking about LiIon batteries? It makes imho less sense to manipulate termination voltages with NiMH batteries.
My MC3000 prototype sample would be a drop in ready to go charger, i had posted its user-set finish voltages here.
Funny thing, some cheap chargers can be modded to do this very easily.
I have a charger I've used for years, and found out it was over charging my batteries a bit.
Cut off a 4.25v causing it to flash bulbs in certain incan lights of mine.
I had to figure out by necessity how to fix it.
Turns out the termination voltage was set by a single resistors value. Change the value, change the cut off.
The clue was in the fact that it was a dual purpose li-ion / lifepo4 charger.
It has a switch to select between the two.
That switch simply changed the resistance on that circuit.
So, it takes some tech know how, but certain chargers can be modded to do this.
......... I have an entry level hobby charger from my RC days and it works pretty well but I'm looking for something that is more "put together". When I use my hobby charger I have to set up a cradle and wires with alligator clips. I'd like something that is a little more out of the box ready to go.
That was what I was thinking and why I sold my hobby charger since I don't have any RC toys. I ended up designing my own charger that gives me a lot of flexibility and adjustability. You can see it in this thread........post #43 for completed unit.
http://www.candlepowerforums.com/vb...n-battery-charger-gt-suggestions-needed/page2
