●-●-● Arc LS 17500 ●-●-●
I had the Arc LS "Slim AA" and "FATTY AA" hangin' around for a while.
I mostly used them for draining AA-cells from remotes and such.
However, some(read: most) of my Arcs had different circuits in them
that could not run from a single (drained) AA.
Of course I could use a 14500 (AA sized Li-Ion), but unfortunately the
14500 has the same capacity as the R123, which is *only* 750mAh.
So why not try the 17500 ? Same height as AA (5cm) and same width
of R123 (17mm). The result is an AA tube which can now fit 17500
Li-Ion cells with 1100mAh capacity. (AW-cells, they're great !).
Whenever I would like to use regular AA's, I use a shrink-sleeve
to prevent the AA from shifting/rattling.
Here are some pics of the mod... Simple, yet effective.
I just had the tubes bored wider by a very good friend...
No more dust for these classic bodies...
Cheers !! :thumbsup:
