jimbo231
The battery voltage is 12.3V, I checked the switch, bulb and continuity of all the wires. Everthing is fine........Is it true the full charge no load battery voltage is suppose to be 12.6v and empty 12v? What could be wrong?
12.6 full yes, low 11's empty. Put the Voltmeter on the battery and turn on the switch, you'll probably see the Volts go to 0 or some very low number. I'd guess time for a new battery.
