Was wonder to power it up by Li-Po but i guess the cell itself will already cost a bomb, lol.
Actually, LiPo cells can be very inexpensive. I use LiPo cells for radio-controlled airplanes and trucks, and I buy all mine from
hobbycity.com. Their
Zippy brand cells in particular are very good, even compared to much more expensive brands. I regularly drain my packs at 20-30 amps, so they're not going to complain about a 3-amp draw.
Since soldering LiPo cells is generally not encouraged for people who don't already have quite a bit of experience with safe handling of the batteries, I'd suggest getting a few packs and wiring up a harness to plug them into your LED driver in series. Three of
these in series would give you 45-60 minutes of runtime and only weight about 1.5 lb.
I personally use
this charger, which would also work well for your project (needs a
12v, 5a power supply).
You'd also need a low-voltage alarm, something like
this, on at least one of the packs, because LiPo cells are very rarely protected, and it'll be hard to tell when your light is dying, since it's so bright. Just like protected Li-Ions, though, the alarm only goes off when the voltage is dangerously low, so ideally you'll always recharge
well before it goes off.
Hope that helps!
(Also, I'm still kinda new here and don't know exactly what the tolerance level is for a bunch of links promoting something. I hope this post is within the rules, but if not let me know and I'll tone it down)
