11 led circuit
  • Thread starter Thread starter **DONOTDELETE**
  • Start date Start date
D
**DONOTDELETE**
Guest
I want to wire 11 20ma leds; parallel, series, or series parallel? Which is best?
www.cl.ais.net/farcir/ has a circular
circuit board that holds 11 leds for $4 that
will fit a flashlight. Look under miscellaneous.
Thanks.
Gordon
Supposedly that board includes locations for current limiting resistors, so I suspect that it is designed with all of the LEDs in parallel, but with each LED on a current limiting resistor.
My favorite configuration is a long series string of LEDs with a single current regulating device on the whole string. This forces the current to be the same in all of the LEDs, and allows you to use a single current regulator for all of the LEDs. The downside is that you need a higher voltage to supply the whole series string, which generally means some sort of boost converter, and if one device fails, the whole light goes out.
-Jon
