Fenix Comparison L1P L1T L2P L2T
I am sorry about the appearance of the columns.
I could not get them to line up properly.
Comparison Chart of Lux @ 1 Meter With Different Batteries
________ Alk ___ NiMH ___ Lith ___ LithIon
________ 1.59v _ 1.40v __ 1.83v __ 3.90v
L1T Low_ 175 ___ 177 ____ 177 ____ 448 *
L1T Hi _ 549 ___ 535 ____ 554 ____ 1245
L1P ____ 523 ___ 514 ____ 508
________ 1.56v _ 1.40v __ 1.80v __ 3.90v
________ 1.53v _ 1.39v __ 1.80v
L2T Low_ 235 ___ 229 ____ 428 ____ 568 *
L2T Hi _ 924 ___ 928 ____ 921 ____ 1347
L2P ____ 760 ___ 752 ____ 754
* After switching to high, the L1T and L2T would not immediately switch back to low while using a 3.90 volt lithium ion battery.
If the light were turned off for a few minutes, it would then work on low. But again, after switching to high, it would not switch back to low without turning off first, presumably to cool down.
Conclusions:
The L1T and L2T do not have a boost-buck circuit, and are not regulated over the full input voltage range of .9 to 4.0 volts. The circuit is apparently only a boost circuit, and anything over 3.50 or 3.55 volts input, will run in direct drive mode, based on the sharp increase in output of the L2T when using 2 lithium batteries totaling 3.60 volts, and an extremely great increase in output, for both the L1T and L2T, when using 3.90 volts.
The increase in output for the L1T on high, when using a 3.90 volt lithium ion battery, is phenomenal, and a thing of beauty. I just wish I knew how much it was reducing the life span of the LED.
Conclusions:
