Handlobraesing
Banned
- Joined
- Feb 14, 2006
- Messages
- 2,724
old stuff:
Update 7/21/06:
I tested the capacity with four cells in series. Since I don't know the accuracy of calibration of the BC-900, it wouldn't hurt to do it a different way anyhow.
4 cells connected in series Cells were fully charged and allowed to rest for about an hour.
~600mA discharge current.
*the watt-hour capacity is of ALL FOUR cells combined.
*measurement uncertainties= thermal coefficient of resistor and 0.025%+1mV voltmeter error.
Great batteries, ghetto testing device.
Tested:
Four Duracell 2650mAh AA rechargeable batteries. Available at Wal-Mart
Charge method: 0.36A x 9 hours on a dumb, timer controlled charger.
They were allowed to sit around for an hour or two, then discharged.
Discharge method: 0.5A, end voltage 1.0v (it should be 0.9v, but stupid BC-900 reads 0.1v lower than actual)
Test result:
2.68Ah, 2.78Ah, 2.78Ah, 2.63Ah. This is what I got the VERY FIRST cycle. Amazing!
Average: 2.72Ah. Notice that every cell's capacity is +/- 4% from the average value. This is very good.
The package says "Made in Japan" and charging instruction says "270mA x 16 hours" which leads me to believe these could be Sanyo 2700mAh. The cells lack the "-HR-" symbol on the bottom, which is consistent with the Sanyo's 2700mAh.
These are very good batteries, however I'm not implying that "Duracell" rechargeables are very good per se. The OEM source they used(most likely Sanyo) is very good.
I have some Duracell 2100mAh Made in China batteries and they're very poor quality (requiring many many cycles before they get anywhere near the full capacity and still having very large deviation in capacity between cells)
Update 7/21/06:
