streamlight keymate mod
Paul6ppca
RI
I put a smjled in the keymate using the 4 lr44 battery. It is very bright, but now its acting up and not turning on consistently.What grounds it? is it tha metal washer above the led?
VWTim
Corvallis (OSU)
Isn't 4 cells too much voltage for a smjled? Perhaps the LED died. My Stylus with a DD 26Mcd did what you're describing when it died.
kitelights
Richmond, VA
I'm gonna take a wild guess that you don't have the plastic sleeve covering all of the cells and that an edge of one of the cells is making contact with the tube.
Paul6ppca
RI
I think I got it, it just needed a bit more solder on the neg lead to make good contact with ground.Works every time now!:)
4 cells is more than reccommended,but they seem to sag under load and its been fine for over a month, so far. I had been using 3 cells in another light and decided to step it up and see if it would hold, and it does. I was think of trying N cell but this is working ,and I have 20+ batteries for it.
The sleeve was covering all the cells,good idea.Ill have to keep an eye on that in the future.
