12volt ssc P7 driver
Goldigger
London UK
Hi,
Im after a driver for a single P7 led, battery pack is 12volts. The driver needs to be as small as possible to fit inside a torch head.
Has anybody got any ideas?
Thanks in advance..
What is the inside diameter of your host?
Taskled.com is one of the better places
For a 12 volt application you want the hipflex but it is 1.4 inches in diameter if you were to power it from one 18650 you could power it direct drive or use the d2flex to give you multi modes.
