You get this. :candle:
Took with a regular/typical camera setting (no + or - stops) with a tripod and no flash.
15 or so feet away from the door.
In this next image, it was taken outside under pretty foggy conditions. The security light you see in the image is, if i'd have to guess, about 200 or so feet away. The fog captures the beam great though, and there's plenty of spill you can't see in this image for walking and up-close useage. And the grass in that area at the end of the beam is visible although you can't see it in the pic.
This is why I'm so gaga over this set-up as an emergency or even regular use light. This combo just rules for useable brightness and runtime.
Here's a reflector size comparison.
Coleman on the left, Mag 4D on the right.
