windstrings
I recieved mine today.. it actually surprised me and got here sooner than I expected.
When I opened the box, I was also surprised at the nice aluminum box provided with had foam padding inside with slots already provided. I knew I was getting one, but not this nice.
The Box has a handle and latches to attach the provided strap if wanted.
or you can use the strap on the light.
When I pulled out the light, I expected it to be much heavier considering how it looked and how it was built.
The body is a composite plastic fiber of some sort that looks like metal.. thats prob what threw me.
The head is bold black anodized aluminum the best I can tell with a reflector glass that looked like it wasn't even there it was so clear.
The unit comes without the battery attached so I took the 6 screws off the bottom and hooked up the wire.
I couldn't wait to go outside once it got dark to test it out.
The only other light I have used to compare it to is the X990.
when I turned it on, it took about 20 seconds to get to full brightness.
I think the X990 did faster, but since the X990 didn't get near as bright, I think it was the same. "if that makes sense".
If your not totally impressed my the looks and the make, when you turn it on, you will become a true believer!
This thing is a sinkin beast! Its bright!... Really Damn bright!
I can't imagine ever needing to go to 75 watts, even though I may change my mind, this thing shines all the way to the end of my block and looks like it would render someone blind even at that distance.
If you were to shine it on your neighbors house at night from a distance of 100 yards, it would surely light every room in thier house!
I don't recommend it.. the poor people would probrably think a UFO landed in their backyard!
The beam focused down is really really nice.. I like it...very smooth.. the very center is even brighter than the main beam.
Its true, you couldn't shine it at an oncoming car even 200 yards away, you would flat blind them and probrably make them run right in the ditch!
I would love to see a BB next to this.. I can't imagine anything could be brighter!.. wow!.....
At this point, I'm sold on having 95 min of runtime... thats awesome!
The air is totally clear tonight and low humidity at my house as follows:
Humidity 58%
Dewpoint 30 in.
Heat index 57F
And when I shine this in the air.. its just like the pictures in the beamshots you've seen on the forum.. they are not lying!.... it looks like a light cannon beaming through the air!
Humidity 58%
Dewpoint 30 in.
Heat index 57F
