BUZ
- Joined
- Jun 11, 2006
- Messages
- 639
Well here is my latest WE's setup the Wolf Eye's 9DX raider, would like to say thanks to Mike@pts as always his customer service and products are top notch! Like the WE's 6MX this setup produce's a very bright and very white beam that has outstanding throw and tons of useful spill! After reading countless posts from Paul_in_Maryland I new I had to give the raider a try and I'm glad I did, one of the thing's I really like about this setup is that you can run the larger LiIon cells (ahh guilt free lumens) & if your in a pinch three primaries (very handy IMO)!
Tonight I did some comparisons to a P60, P61, P90, P91 and the 9DX simply smoked em', the size of the raider is basically the same as the 6MX only difference is that it's about a inch longer (bezel dia. is the same). To anyone looking for a fairly compact torch that produces a lot of light well look no further this baby really screams!
The cells and charger that I got from mike seem to work quite well, when I compared them to three primaries and two of AW's 18500 cells the WE's cells actually seemed to provide a little better output? Another thing that's nice is that the WE's charger is much faster than the DSD charger (think the dsd charge rate is 350mAh & the WE's is 750mAh)!
SPECS:
Output power 200 Lumens
Continuous runtime 60 Minutes
Lamp assembly 9.0V D36 Avanced Xenon (shock resistant)
Battery type 2 - LRB-150A Li-ion Rechargeable
Tail cap Tactical button switch; morse and continuous
Body diameter 25.4mm
Bezel diameter 42mm
Weight with battery 10oz
Length 163mm
http://www.pts-flashlights.com/
SPECS:
Bezel diameter 42mm
Length 163mm
