zgurl said:Hi Pumaman,
Nice mod. It even seems that I would be able to do that. Anyway, it is clearly worth trying it. So I just ordered some Crees... and hopefully I will make my first "mod"
What sort of runtime do you get with that mod?
update.
decided to try the mcr17xr reflector from the sandwich shoppe. Had to file off about 3 mm off the front to fit it in the eos. Taking that much off the front gives the reflector a little bit of the famous dark ring in the beam, but not enought to affect real-world use. and as you can see its much better than the ims17. now a beautiful, bright beam in a compact headlamp:rock:
Did you use the black plastic optic/reflector holder at all? Or did you just tape it like in the pic and let the pressure hold it when enclosed?
-Ed
