ManBearPig
- Joined
- Jan 15, 2007
- Messages
- 47
Ok here's what iI have going on. I built motion detecting video camera that I leave out on my property for weeks at a time. It uses a Sony Handycam with nightshot that I modified to record day and night in IR. The camera has a built in 6 volt 8 watt light that I set to come on automatically at night. I put an IR filter on the light but I'm not happy with it. Unless the subject is real close to the camera you cant see much. It also drains the battery much quicker. So I want something that is brighter with less battery drain.
I purchased one of these: http://cgi.ebay.com/5-Watt-Infrared-IR-LED-Night-vision-camera-Flashlight_W0QQitemZ250073863684QQihZ015QQcategoryZ26207QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
along with one of these: http://cgi.ebay.com/5-Watt-LED-Pulse-Driver-for-Luxeon-White-Blue-Green-IR_W0QQitemZ250070430935QQihZ015QQcategoryZ36323QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
and a 15 degree lens.
I've never messed with a luxeon style LED before so I need a little help to see if I'm doing this right.
If I hook the red+ and black- wires from the driver to the 6 volt +/- light output on my camera, then the yellow wire to the + on the LED, white to -, I should be ok to go right?
Any input would be appreciated.
