●-●-● Bombelman Arc LS First Run FluPIC & SSC mod rev2.●-●-●
The Proud owner of this light my chime in at any time...
This mod is revision2 of my first ever mod, on my first ever
High-Power (LuxI haha) first ever Arc LS (First Run) Flashlight.
(Read that here: https://www.candlepowerforums.com/threads/109380)
A year later, the heatsink has been refined:
Custom made in the UK from high-quality Brass.
(details here: https://www.candlepowerforums.com/threads/154563)
The Circuit custom-made and programmed in Canada:
0.55" 0.6mm thin FluPIC v2.1 (oldskool) with Alternating Strobe.
The Led used is a Seoul USW0H from PhotonFanatic.
The reflector used is the 17mm SSC-optimized reflector, from the same source.
This setup can run from 3.0v and 3.7v cells, even from a CR2.
See pics posted below of this head and bezel on a CR2 tube.
(If you did not notice it in my avatar.........)
Cheers !!!
Questions, comments and suggestions more then welcome !
(PLEASEEEE, NO PM ! e-mail to george (at) bombelman.com Subject: CPF-CPF-CPF-CPF)
L: Stock Circuit - M: Custom Heatsink top - R: FluPIC 0.55"
L: Stock Circuit - M: Custom Heatsink Bottom - R: FluPIC 0.55"
Dry-fitted the FluPIC in the heatsink
Wires soldered, FluPIC Epoxied
Showing bottom after soldering
Seoul USW0H Epoxied and Soldered.
Shown in the head.
Beze-View.
Centered Perfectly, show nice yellow reflection of the die...
Bombelman CR2-body.
Cheers !!!
Shown in the head.
Beze-View.
Bombelman CR2-body.
