8/25: Updated LF5 runtime
8/21: Updated Lux reading and LF3/4 runtime
8/12: Beamshots added.
(Please refer to LF2 for this beacon series flashlight)
Just got the new LiteFlux LF3/LF4/LF5 in Beacon Series (LF2~5).
The dimension summary:
The main difference to the previous LF2 (Cree/SSC P4):
1. LF3/LF4/LF5 will be only in SSC P4 U-bin
2. They use the new Deep Smooth Reflectors
3. The compensation in battery voltage reporting function changed to make the reporting near the open circuit voltage.
4. The manual mode settings now could be memorized. :thumbsup: (Also available in latest LF2)
5. The diffuser is direct insert, no need to un-screw the head cap.
6. Comes with blue, yellow and red color filter to use with the diffuser.
The length of LF3/LF4/LF5 seem longer than other similar flashlights. It's because of the two-stage twisty swicth (6mm) and the new deep SMO reflectors.
The battery type accepted:
LF3: CR123A, RCR123 (3.0v/3.7v), 16340
LF4: CR2, RCR2, 15260
LF5: Any AA type. Alkaline, NiMH, L91 lithium, 14500
If voltage below 2v, LED will be driven at 350mA. If above 2v, LED driven at 700mA.
Here're some photos. Sorry for the poor quality and color. :green: Still busy on works, will take more photos and beamshots in a few days.
=== Family Shot ===
(Left to Right: LF1 v2.0, LF2 Cree XR-E, LF2 SSC P4, LF3, LF4, LF5)
LF1 added with large head and diffuser
The lanyard holes were changed in LF3/4/5 (the same). Now they're two holes, two slot and two notch. It's more useful with split rings or clip.
With diffuer
With color filter (not clear because of bad DC setting...)
Another shot (Over exposed )
Wood box. The top one is old version LF2 without the label. Newer boxes all have the label.
=== LF2 Cree XR-E ===
=== LF2 SSC P4 ===
For more LF2 informations, please refer to my mini-review at: https://www.candlepowerforums.com/threads/154068
=== LF3 SSC P4===
=== LF4 SSC P4===
=== LF5 SSC P4===
==== 8/12 Beamshots added ====
The DC settings seems not good and the results are not good also. Too lazy to take again. May do if have more free time in the future.
Each lights with two shots. The settings are 1/2s F8.0 for first one and 1/8s F8.0 for second. LF2/3/4/5 all use li-ion btteries and use factory P2 (50%). It's about 50cm to the wall.
JETBeam C-LE (NiMH, Medium):
Fenix P3D rebel 100 (2x RCR123 3.0v, Medium?):
LF1 (CR14505 3v, High):
LF2 Cree XR-E:
LF2 SSC P4:
LF3 SSC P4:
LF4 SSC P4:
LF5 SSC P4:
Longer range (3m?) indoor shots:
JETBeam C-LE (NiMH, High):
Fenix P3D rebel 100 (2x RCR123 3.0v, High?):
LF2 SSC P4 (10440, 100%):
LF3 SSC P4 (RCR123 3.7v, 100%):
LF5 SSC P4 (14500 3.7v, 100%):
LF4/5 should be the same, but I forgot to take LF2 Cree.
=== Family Shot ===
With diffuer
=== LF2 SSC P4 ===
=== LF3 SSC P4===
=== LF4 SSC P4===
=== LF5 SSC P4===
LF2 Cree XR-E:
LF2 SSC P4:
LF3 SSC P4:
LF4 SSC P4:
LF5 SSC P4:
