LiteFlux LF2 mini review (6/4 updated with SSC P4 runtime)
EDIT: 7/2 updated with SSC P4 lux reading at 1m
EDIT: 6/4 updated with SSC P4 runtime
EDIT: 5/19 updated with SSC P4 version
EDIT: 3/7 updated lux reading and runtime with 10440 for new firmware.
LF2 is the first flashlight in new "beacon" series manufactured by LiteFlux. It has a 2-stage mechanical switch and MCU controlled circuit with 4 operation modes and 5 functions. There're some discussion about it: http://candlepowerforums.com/vb/showthread.php?t=150055
Official Product pages: LF2 Cree XR-E Version (There's a Quick start manual with flowchart)
Spec:
My LF2 comes with a diffuser, 3 o-rings and a sheet of operation manual.
Size comparision with LF1:
With diffuser:
The LF2 doesn't look fancy, it has two flat surface and two slots on the tube. You could install some tritium vials in the body slots or use some glow-in-the-dark paint to make it easier to find in the dark. The tube tail has two holes and two short slots for attaching lanyard and keychain ring. There's no notch, thus attaching a keychain ring may affect the tail-stand ability (Someone suggested LiteFlux already).
Disassembled:
Head and tail:
Inner head and tube:
LF2 with diffuser and LF1 with LargeHead and diffuser:
Some Beam shots:
EV 0.0
EV -0.9
EV -1.5
LF1 (1xAA) at left and LF2 at right:
EV 0.0
EV -0.9
EV -1.5
The beam shots aren't good. I'll re-take them after I get my new DC.
LF2 has 4 operation modes and 5 useful functions. It's good that you could directly select any mode or function at any time, there's no need to cycle through each of them.
4 Operation mode:
Removed. Please refer to official quick start manual on LiteFlux web site.
(There're some flow charts in the operation manual, I think they should be clear than my writing)
It may look very complicate at first, but after using it, I feel it's not so hard. It'll jump to the previous mode when switch on. If using the standard mode most of the time, just 1/4 turn(P1) or another 1/4 (P2) will go to my two favorite output levels. If it's not in standard mode, just 1x SW will quickly jump to standard mode.
Since the input voltage range is wide, basically any AAA battery will fit. But be careful with 10440 li-ion rechargable batteries. LF2 will drain over 600mA when using Li-ion with 100% output. I think it's over the recommended 1.5C discharge rate.
LF2 output level is controlled by PWM, but the frequency is high (7.8KHz). I couldn't feel the flickering even in lowest level (0.2%). I could easily feel it with my JETBeam C-LE and MK.II X. One problem is sometimes the output isn't stable, I only have one LF2 and not sure if it's only in my LF2. I'll got another LF2 with SSC P4 when available, and I'll compare them.
I didn't have other AAA sized flashlights at hand to compare with, but I think I won't buy another one. :naughty:
Updated on 2/22
Lux Reading at 1m (factory default P1 and P2):
10440:
NiMH:
Here's my LF1 with 1AA NiMH for reference:
Runtime Chart:
Tests were done in my closet. No light box or similar device used, the reading is directly take from the sensor and distance of the lux meter and light was about 40cm. Reading was taken at 1min interval.
I use eneloop AAA to do the run time. They were tested 804, 802 and 796mAh at 500mA discharging rate on my MAHA MH-C9000. When testing with Alkaline batteries, the overdischarge protection was turned OFF, and turned ON with NiMH batteries.
Alkaline battery (Energizer LR03 AAA):
NiMH battery (eneloop 800mAh):
Almost a flat line with factory default P1 output.
10440 (320mAh):
The unstable output and output level were fixed with the new firmware. The runtime of 10440 seems not very smooth but I couldn't feel it with my naked eyes. I didn't do a 100% runtime since the current may exceed the recommended discharging rate of 10440.
Updated on 3/3:
Factory Default Settings:
Added on 3/7:
Just took a photo to demonstrate the PWM feeling. As I said before, LF2 uses PWM but I couldn't feel the flickering with the lowest 0.2% output. I use another JETBeam flashlights as reference, and you could feel the frequency difference. All flashlights are using one NiMH battery and adjuest to lowest setting. Top is LF2 (0.2%), middle is C-LE (low) and the bottom is MK.II X (5%):
==== 5/19 Updated with SSC P4 version ====
Just got the SSC P4 version of LF2 this morning. :devil: Here's a quick comparison.
The XR-E is 80mm, and SSC is 77mm:
(Upper is SSC P4 version)
Head shots: (Left is XR-E, right is SSC P4)
The reflector of SSC P4 is shallower and it's about 4.5mm. The XR-E version is deeper, about 8mm.
The OP reflector of XR-E is heavier.
The SSC P4 is put on the anodized head cap and the center hole of reflector is larger.
Beam shot around 20cm: (Left is XR-E, right is SSC P4)
both use NiMH and in P2 position. DC isn't white balanced.
EV -0.9
EV +0.0
EV +0.9
It's a great floody light for short distance use.
==== 6/4 Updated with SSC P4 version ====
It's roughly about 2/3 of Cree version. Maybe a higer Vf? :shrug:
10440 (360mAh, started from 4.13v):
Updated on 7/2
SSC P4 Lux Reading at 1m (factory default P1 and P2):
NiMH:
Spec:
- Two model: Cree XR-E and SSC P4
- Size: XR-E model: 80mm(L) x 14mm (D), SSC P4 model: 76mm(L) x 14mm (D)
- Made of aircraft grade aluminum
- HA III Hard anodized finish
- Battery : single AAA (Alkaline,Ni-MH,Lithium) batteries
- single 10440 Li-Ion is available
- Switch : twist
- Input voltage : 0.9V ~ 5.0V
- 4 operation modes
- 6 user defined output
- 1 user adjusted output
- 4 functions
- Weight : 17g (excluding battery)
- Waterproof
- Glass lens with AR coating
- Candle mode available
- Accessories : plastic light cover,O-ring,silicon oil
- Wood gift box
With diffuser:
Disassembled:
Head and tail:
Some Beam shots:
EV 0.0
EV -0.9
EV -1.5
EV 0.0
EV -0.9
EV -1.5
4 Operation mode:
- Standard mode: Two user configurable output levels. (Using programming function to set and store)
- Manual mode: Adjustable output level, you could adjust it on the fly from 0.2% to 100% (256 levels, Default to 50%). It won't be saved after you leave this mode.
- Strobe mode: Two user configurable strobe mode. Both the output level and strobe pattern are configurable. (127x127 patterns)
- SOS mode: Two user configurable output levels. The SOS signal pattern is fixed.
- Programming function: Most important function of LF2 used to configure the standard, strobe and SOS mode.
- Battery voltage report function: Use the flash pattern to report the battery voltage.
- Demo function: It'll demo through all modes.
- Rechargable battery over-discharge protection: It'll set the proper limit automatically for NiMH and Li-ion. When the voltage drop to 3.0v for Li-ion and 1.0v for NiMH, it starts to flash 3 times every 40 seconds. When the voltage drop to 2.8v for Li-ion and 0.8v for NiMH, it'll do fast strobe about 8 seconds, then turn off the light. (It still drains about 1mA, so swap the batt before it drop into this state).
- Reset function: If you mess up something or want to restore the default, select this function will clear the EEPROM and restore the factory defaults.
Updated on 2/22
10440:
100%: 590
50%: 281
0.2%: 3
P1: 76
P2: 288
50%: 281
0.2%: 3
P1: 76
P2: 288
NiMH:
100%: 248
50%: 132
0.2%: 1
P1: 36
P2: 129
50%: 132
0.2%: 1
P1: 36
P2: 129
High: 305
Low: 37
(Seems too low for my LF1?)Low: 37
Runtime Chart:
10440 (320mAh):
Updated on 3/3:
Added on 3/7:
EV -0.9
EV +0.0
EV +0.9
Updated on 7/2
NiMH:
100%: 256
P2: 140
P1: 41
0.2%: 2
10440:P2: 140
P1: 41
0.2%: 2
100%: 565
P2: 270
P1: 66
0.2%: 2
P2: 270
P1: 66
0.2%: 2
