was.lost.but.now.found
I have been doing quite a bit of searching and can't seem to find a couple answers to some questions. I don't totally understand why these two batteries both exist when they are so close in size. Please help if you can - thanks in advance.
Would it be correct to say that in all cases 1 x 17670 will directly replace 2 x CR123 in LED lights (based purely on size compatability)?
Would it be correct to say that in some cases 1 x 18650 will replace 2 x CR123 in LED lights (based on space tolerances or boring out)?
If diameter is the only thing holding the 18650 back, then why didn't they make it a "18670" to get every little bit out of the space?
Are there any other considerations that need to be made when comparing compatibility?
Thanks for the help.
