- how should i store my 18650's, charged or discharged?
- do they have memory effect? i mean, should i completely discharge them before charging again?
- how long can they keep their energy without being used? i mean, would they be ready for use if i store them charged? or i should charge them just before use?
- are there any safety reccomendations for charging them, besides not leaving them alone?
- do they get too hot while charging? should i place a fan or cooler in front of them while charging?
- are there any hints to prolong their life?
- my light (fenix tk12) can use either two cr123a or one 18650. what do u think would be the advantages and disadvantages of both?
thax 4 the help
first off, heres some reading to do:
Rechargeable Lithium Battery Information - Protected vs. Unprotected Li-Ion Batteries
Read through the basics of Mdocod's
MDs Lithium-Ion > Incandescent guide + compatability/comparison chart thread
Enough reading, look at these pictures
Vidpro's "illustrated battery charging concept"
http://www.candlepowerforums.com/vb/showthread.php?t=235745
Vidpro did a good job explaining why cells heat up here, as well as illustrations beginning in post 4
http://www.candlepowerforums.com/vb/showthread.php?t=270416
If you like to see the technical stuff, consult NewBie's
Li-Ion protection technology and possible dangers thread
There are battery experts aboard the forum, but I'll just share what I know
btw, :welcome:
It is preferred to have the cells charged for storage. Never attempt to completely discharge cells [~3.8V under load]
I've stored my 17670s for a month without significant drop in charge, but then again I'm storing them in a place where its 77F all year and out of the sun. With basic common sense storage practices you should be fine. I bought rechargeables to eliminate my use of CR123As for nightly excursions, so usually my cells are cycled over and over, barely left in storage for half a month.
Since there are many different types of chargers available, I recommend you to read through Mdocod's
Consumer Li-Ion "cradle" charger roundup thread to get a better handle on what charger to buy as well as the characteristics of your charger.
Like all batteries, once its capacity is saturated it will begin to convert the additional energy into heat. If your batteries [I'm assuming unprotected] are heating up during charging. It is likely to originate from two possibilities:
the first is your charger is unable to terminate charge accurately. The other is that the charger only has a single channel, but you are charging two cells in parallel and the cells have a different state of charge between each other. This causes one cell to be overcharged and the other undercharged.
I would prefer to have protected cells in my collection because they protect from overcharge and overdischarge by disconnecting the battery :)
Note that due to internal resistance any battery chemistry will heat up slightly during charge [as well as discharge], this is normal. It should be warm to the touch and not "hot"
Prolonging their life requires some understanding of battery conditioning, and honestly I'm not doing a good job on mine:shrug:
its debatable on advantages and disadvantages of rechargeables because it involves a couple variables to which you as a user can apply.
If the driver of your light is capable of either, the 18650 is a batter choice, but keep in mind that 2xCR123A has a overall dimension of twice the length of a cr123A, ANSI dimensions as "16340" or 16mm wide, 34mm long, cylindrical. 2xCR123A is then comparable in width to a 16mm wide and approx 68mm long cell. Its closest alternative is actually the 17670 cell. 18650 is the same length but 2mm wider, so normally on lights designed for cr123as 18650s would not fit.
if you use your light only sporadically, rechargeables are not a good investment, especially considering the additional costs of charger and stress:p .
However, if you use your flashlight every night, rechargeables are the better option because it saves the cost of replacement cells.
There an abundant amount of information on the forum for Li-ions simply because there are so many users here who uses them :)
