ernsanada
- Joined
- Apr 29, 2004
- Messages
- 2,962
I just received the Tiablo MA6 Q5.
The Tiablo MA6 can be purchased at Battery Junction
Specs from Battery Junction.
Step up and down constant current driver, with High efficiency dual mode DC-DC regulator (PWM / PFM) and Li-ion battery protection circuit cutting power when under 2.7V or over 8.4V.
Includes 2 switches: A multifunction 3/5 mode switch and a 'forward tactical click' with momentary feature.
The Multi-functional anti-flickering MCU controller switch operates as follows: In Mode I, the switch has 3 levels of brightness in the following sequence: 100% > 50% > 20% In Mode II, the switch has 3 levels with S.O.S./Strobe in the following sequence: 20% > 50% > 100% > S.O.S. > Strobe
Battery types supported are: One 17670 Li-ion battery; Two CR123A or RCR123A batteries. I know there are many out there that wanted this light to use a 18650 battery, but sorry it does not fit. It does not bother me.
The fit is excellent.
Made of Aircraft aluminum T7075.
Toughened ultra clear glass lens with AR coating.
The Type III Hard Anodize has some flaws in the finish. There is a slight mis-match of color between the Lens Bezel Assembly and the rest of the body.
The switch action is very easy. Came with the reverse clickie installed. Will not tailstand.
The beam is nice and white.
The corona is slightly off-centered. I have a Tiablo A9 Q5 with the same problem.
Comes with a holster. Installed Bezel down. The snap on the top of the holster took some time to attach. They should have left a little more room for some play.
I like the clip but I have already read that many out there don't like the look of the three hex screws. This does not bother me.
Comes with a lanyard.
Comes with a forward clickie, o-rings and GITD Rear Rubber Switch Cover.
Rear view of the Lens Bezel Assembly.
This is where the +ve battery makes contact with the Cree Q5 Module.
Inside view of the Rear Clickie.
Inside view of where the 3 Hex Screw's go.
Fits AW's Blue Protected RCR123's with ample room.
Size comparisions.
Left, Tiablo MA6 Q5. Right, Tiablo A9 Q5
Left to right, Tiablo MA6 Q5, Regalight WT1 1st Gen Q5, Lumapower M1 Q2 1st Gen, Olight T20 Q5
I also took lux readings of the lights shown above. These are the lux readings I got. I am using a Meterman LM631 Light Meter measured at 1 meter. I waited 2 minutes before taking the readings. I am using AW's Protected RCR123's which were fully charged.
All lights using 2 Protected RCR123's.
All lights except the Olight T20 Q5 are using SMO Reflectors. Olight T20 Q5 is using the half SMO and OP Reflector.
Tiablo MA6 Q5 - 13,600 lux @ 1 meter
Tiablo A9 Q5 SMO, 2 RCR123, - 19,260 lux @ 1 meter
Regalight WT1 1st Gen - 11350 @ 1 meter
Lumapower M1 Q2 1st Gen - 4550 lux @ 1 meter
Olight T20 Q5 - 2790 lux @ 1 meter
Tiablo MA6 Q5 @ 87"
Tiablo A9 Q5 @ 87"
Regalight WT1 1st Gen @ 87"
Lumapower M1 Q5 @ 87"
Olight T20 Q5 @ 87"
Left, Tiablo MA6 Q5. Right, Tiablo A9 Q5 @ 87"
Left, Tiablo MA6 Q5. Right, Regalight WT1 1st Gen @ 87"
Left, Tiablo MA6 Q5. Right, Lumapower M1 Q5 @ 87"
Left, Tiablo MA6 Q5. Right, Olight T20 Q5 @ 87"
Left, Tiablo MA6 Q5. Right, Tiablo A9 Q5 @ 87" Stepped down exposure
Left, Tiablo MA6 Q5. Right, Regalight WT1 1st Gen @ 87" Stepped down exposure
Left, Tiablo MA6 Q5. Right, Olight T20 Q5 @ 87" Stepped down exposure
Size comparisions.
Tiablo MA6 Q5 @ 87"
Tiablo A9 Q5 @ 87"
Olight T20 Q5 @ 87"
