HgRyu
I made some multi-mode buck-boost drivers for my project (comming soon... ) and have some surplus from test version. So I made some Multi-mode led module compatible with sandwich.
1. Quantity for sale : total 9 sandwiches
#1 - acourvil
#2 - TIP AND RING
#3 - darkzero
#4 ~ #9 - PhotonFanatic
I have Madmax sandwich which I don't use and I'll let it go.
#10 (Madmax lite with SSC P4 USXOH, upgraded from Lux-III TWAJ)
2. Price : U$35 for #1 ~ #9, U$20 for #10
3. Shipping : U$3, airmail shipping to everywhere (not responsible for lost or demage)
4. Payment to hgryu(at)hanmir(dot)com via Paypal only (no additional Paypal charge)
5. Post here "I'll take #?"
6. I'll add brass tab for + battery contact as below picture. You have to remove brass tab to use the sandwich in Mag-2AA but I don't recommand this sandwich for Mag-2AA as this driver is buck-boost and have minimum input voltage 1.8V, this will cause short runtime compare with boost (only) driver. BitZ driver is optimized for protected rechargable Li-Ion battery.
7. Original FireFly I & II use Luxeon led so there can be bad focus and beam with my sandwich. I have FireFly-II but don't have original optic so I can't tell what will happen.
8. My converter is not designed for sandwich so my sandwich don't have perfect fit and shape, also I think you can't upgrade led later (or very very difficult..)
Runtime Graph
Specification
- LED : SSC P4 bin - USXOH
- Driver : High efficient Buck-Boost converter with 3 regular brightness levels and 4 hidden signals.
- Battery : One 3V CR123A or one 3.6V RCR123A (recommend AW's protected Li-Ion cell)
- BitZ driver use high efficient Buck-Boost converter and it will control power to the LED even though you use 3.6V rechargeable Li-Ion battery. So, LED will not be damaged by unregulated high current from Li-Ion battery. Off course, birightness by regular 3V CR123A and 3.6V rechargeable Li-Ion battery will be same.
- Input voltage range : 1.8V ~ 5.5V
- There are basic 3 Brightness levels (Medium-Low-High) and hidden 4 Signals (Strobe-Locator-Extreme Low-S.O.S.)
- Brightness (estimated) : High (120~130lumen), Medium (30~40lumen), low (10lumen)
- Current to LED (tested) : High (500mA), Medium (150mA), Low (30mA)
- Rumtime (tested) : High (1~2 hours), Medium (3~6 hours), low (12~24 hours) depending on 3V or 3.6V. (see below runtime graph for details)
- Runtime for Signal mode (tested by CR123A) : Strobe (7 hours), Locator (36 hours), Ext.Low (70 hours), S.O.S. (3 hours)
- Basic 3 brightness levels has Memory Function. You will get next level by Off and On within two seconds.
- You will get into Signal mode by consecutive 8 On and Off. No memory function in Signals.
- Locator signal : useful mode for tracking and camping as "follow me" signal or location signal.
- Extreme Low : This mode is useful as a overnight candle at tent. Current to LED is 10mA.
#1 - acourvil
#2 - TIP AND RING
#3 - darkzero
Runtime Graph
