It was only a matter of time; I was curious which of the majors would come up with them first. Looks like Truck-Lite:
single-emitter 4" round turn and stop/tail lamps — the stop function takes 3.5w, which is roughly 1/8 the power consumed by an ordinary P21W incandescent stop lamp bulb.
(also 2-emitter 4" round rear fog lamps)
These meet ECE regulations; doesn't look like they're SAE/DOT certified. Minimum intensity is higher for the stop and turn functions in SAE/DOT, but visibility angles are wider in ECE. So it's probably only a matter of a little more time before DOT versions of these become available. There's been a great deal of hand-wringing about LED 4" round lamps not meeting the DOT's minimum requirements for effective projected luminous lens area, because of the dark gaps in amongst the emitters. This single-emitter device, depending on optic design, may solve this problem (or may aggravate it). I want to see them all in person, but I'll be especially interested to look at the rear fog, which would meet DOT stop lamp photometrics. I can't tell from the images on the site whether EPLLA would be a problem or not.
