Chrontius
What's "the difference between mostly dead and all dead?" - either way, time for you to find out. I bought Bhustan's Maxfire Rechargable, and the following mail describes the catastrophic failure thereof that happened about ten minutes ago by the time I finish here.
Further clarification - the top contact was a nubbin that should have been inside the shrink wrap, that was nearly the width of the stick. It had seemed a little loose, but I just squished it back in place and considered it fixed (for now). I think it shifted just enough to short to the metal sleeve serving as a conductor in the light, and the resulting short caused the teeny little negative contact spring to do its best impression of a tungsten filament, and melt the switch element, resulting in the smoke and bad stuff.
The moral of this story: Make sure your battery sticks have nothing sticking out of the + end to short with! Then check your lamp assemblies to make sure that nothing else is touching places they shouldn't!
The battery stick or switch - not sure which - suffered a catastrophic failure just a minute ago. I was playing with my shiny new P61, which worked - sort of - but the battery was thoroughly dead due to self-discharge. I topped it off for a few minutes, and tried swapping in my M60, and while I was putting the P61 into the 6P for comparison, (both would be driven at optimum levels, for at least a little while, I noticed the clicky was stuck forward ... and a funny smell. And a slight hissing. I bolted for the pool deck, where the light now sits disassembled; the tailcap spring was either eaten by a battery leak or the switch melted due to a short with the top electrode (which now seems a little loose, and either way the switch is kaput for now). I'm going to operate on the 'stupid stick shorted' theory for the time being - did they offer any kind of warranty on their work?
