1D P7 M@G Mount
JustinS
Australia
Hi,
Has anyone come up with an ingenius way of mounting a 1D M@G to the handlebars of a mountain bike?
Finding a clamp/mount that opens to the D's 39mm body tube is hard. Any ideas?:thinking:
Cheers
Justin
Im using two of these, one 22mm for the bars and one 28mm for my C Cell, they do come in 32mm for larger copper pipe just bolt though the center and push on, might need a piece of inner tube to stop it moving on the bars but mine is solid, it took quite a bit if force to push onto the torch and bars.
Hope this gives you some ideas:naughty:
I had the same problem as you a while ago and I think I found a good solution:
In my Maglite P7 bikelight I'm using the Electron handlebar bracket from Brum's groupbuy over at the MP. I had to modify it a little bit but now it fits perfectly and it doesn't shake a bit when I mount it on my bike handlebar. The only disadvantage is that you have to bore a hole into your Maglite to attach the mount to the Maglite.
Here is a picture of the mount:
rayman
