I'm modding a bicycle headlight to run 2 Lux 3W emitters on 4AA NiMHs. My current plan is to run the emitters in series off either a BB400 or 500. I'm assuming that 2 emitters on 4AA will have comparable runtime to a sandwich running on 2AA, giving the BB400 3 hours on 2300mAh batteries. I would like to move up to the BB500, but I want around 2 hours of runtime on the same batteries. Is this reasonable, or should I stick with the 400?
The headlight features a high/low/off momentary switch and what appears to be regulation. The battery voltage on high drops steadily under load (cheap heavy-duty cells), but the lamp voltage stays pretty level. I want to keep the switch, but running two regulators in a row seems like a very bad idea. Gutting the electronics and using a mechanical switch is a viable, but non-preferred solution.
