2 or 3 mode driver with a 1A output?
Flo1
Sydney, Australia
Can anyone recommend a 2 or 3 mode driver with a 1A output. I really only want to be able to switch between full power and a lower power setting for the times when full power is not required. I don't need strobe or SOS functions..
Also, I want to run a quad XR-E setup so is it better to use a single driver and run the emitters in series or have two or more drivers and run the emitters in parallel? The battery will be Li-ion 18650's..
You may get better answers by putting this in the correct sub forum. EG Homemade and modified.
