Mr. Merk
I just acquired a 2005 Silverado 2500. The forward lamps appear to be in good condition which leaves me to believe that they've been replaced at some point, likely with aftermarket garbage. I'll inspect further.
Unlike my 2005 GMC Sierra, I'm unaware of any better lamp options other than standard OEM replacements. I plan to use the Phillips Xtreme Vision 9006 in the lows and 9011 in the highs. Would it be best to enable high+low beam operation via relay or add auxiliary driving lamps enabled with the high beams?
I also plan to replace the Silverado tail lamps with the better design of the GMC lamps with 3457 bulbs in place of 3157.
Any other suggestions?
