Tri-flupic in parallel?
AlexGT
Houston, Texas
Free bump!
Hope you get the answer soon, I want to do the same thing to drive a P7 led from a li-ion cell.
AlexGT
darkzero
Flashaholic* ,
SoCal
I only wired it that way to save space since going into an Arc LS that was an issue.
Basically all you need to do is wire all three positive connections into one & connect one ground. You don't need to wire three grounds cause ground is common.
