donn_
I've had this for months, and just stuck a pair of 6V lantern batteries in, and it works...sorta.
The bulb is a Philips 4509, 13V 100W PAR36 Aircraft Landing Spot Light. It has an axial filament, approximately 1/4" long, sitting almost all the way out to the clear lens, in a 4.5" diameter smooth reflector.
It projects a vertical image of the filament, in a dull yellow. It's pretty obviously being under-driven. From the way the cells go in, and the arrangement of their contacts, it seems to be in powered in series, but I'm not positive about that.
Is it possible to get more poop out of this thing by substituting a lower voltage, higher wattage bulb?
Or, should I look at having it completely re-wired inside to make more modern use of the battery space and light engine?
Ideas? I'm thinking incan here. I know I could send it to LedZep and have the window filled with LEDs with a pot knob replacing the toggle switch, but I have another lantern which may have that fate.
I'm looking for more flood, and more light overall. I'll consider bulb replacements and alternative power sources, like a couple of big LiFePO4 packs to replace the 6V lantern alkies.
