Please rate beam quality of this $10.78 light
rmteo
Colorado, USA
On a scale of 1 to 50, please rate the quality of this beam shot. If you like, you can give separate ratings for spot, spill, smoothness, tint, overall quality, etc. Picture taken with the light at a distance of 1m. from the wall, angled upwards slightly - emitter is a Cree XR-E. Thanks for your time.
BTW, diameter of the spot is about 9in., and the spill is about 50in.
Oddjob
London, Ontario, Canada
Re: Please rate beam quality of this LED light
It looks pretty good to me. No artifacts, decent tint, bright spill. The hotspot is a little too defined for my liking but that is just personal preference. I say maybe 45 out of 50.
Benson
About 45. The hotspot's wider than I like, but otherwise perfect. (To the extent I can tell from a 448x336 jpeg, and assuming the tint isn't objectionable.)
rmteo
Colorado, USA
Thanks guys, you're great. lovecpf
A lot has been written about the LF3XT's beam quality. Can someone compare this with the LF3XT? I'm trying to get a feel for what is considered good beam quality.
kramer5150
Palo Alto, CA
Pretty good beam quality IMHO. I'd give it a 45/50 (Malkoff M60 being a 50/50 score). Color tint looks a little green though.
seaside
That's pretty darn smooth. I'd give 45/50.
WHAT FLASHLIGHT IS THAT? I want to have one.
ANDREAS FERRARI
The Great White North
I have to go along with everyone else and say 45/50.I would like a little more spill but the fact that it is artifact-free really does it for me.
DHart
Sonoran Desert ~ Scottsdale, AZ
It's a throwy beam for sure. To someone desiring a throwy beam, that would possibly rate a 45+, for throw. And it's relatively free of artifacts, which scores well. However, the color looks a bit green for my liking.
For general use, I prefer a less throwy light. I like throw for specific applications where that's what I NEED, but not so much in a general purpose light.
For general purpose use, I'd rate that beam about a 35/50 for pattern, 35/50 for color, and 45/50 for lack of artifacts.
For general mixed-use applications, I prefer lights that have a wider central beam with a much more gentle, gradual, and smooth transition into a bright-ish spill. What I'm describing is what you will find with the LF3XT. I am among those who consider the LF3XT to have a near perfect beam pattern (for general use), excellent color, and relative freedom of artifacts.
The beam in the example above is not like that of a LF3XT.
Axion
Big points for appearing to not have the dreaded cree rings. If it were in a better tint (say 5A) it'd be a soild 48/50 to me. Now add in a corona around the hot spot and you'd have my ideal light. Sadly, just a thing doesn't seem to exist. The closest I've found in real life are the warm Malkoff modules.
rmteo
Colorado, USA
For general use, I don't want a throwy light. I only like throw for specific applications where that's what I NEED, but not in a general purpose light.
For general mixed-use applications, I prefer lights that have a significantly wider central beam that very gently, gradually, and smoothly transitions into a bright-ish spill. What I'm describing is what you will find with the LF3XT. I am among those who consider the LF3XT to have a near perfect beam pattern (for general use), excellent color, and relative freedom of artifacts.
Thanks for the insight. I took a look at the review of the LF3XT here:
https://www.candlepowerforums.com/threads/218912
The LF3XT definitely has a larger/wider spot and brighter spill compared to the other lights in the review. I think mine is pretty close to the 120P and Horus - the others appear to be ringy.
The tint is less green than it appears - my simple P/S camera probably does an auto white balance (and auto exposure) that shifts it towards green. I need to get a digital camera with manual exposure settings.
Painful Chafe
Maybe I missed it, but what light are we looking at?
Oddjob
The LF3XT hotspot is not so defined with a nice transition into the spill. The spill is also brighter.
fenixflashaholic0537
I would like a little more spill, but it's a very nice beam with no artifacts or halos. I would give it a 42 out of 50
BlueBeam22
*Super Flashaholic*
48 out of 50. It has a perfectly formed hotspot with a very nice wide spill circle. I see no rings, no artifacts, and no decreasing layers of brightness in the spill.:)
rmteo
Colorado, USA
I am waiting on my lux meter to arrive to get some readings of this light. In the meantime, here are some numbers courtesy of old4570:
Ultrafire RCR123A 3.7v Fully Charged
Hi - 0.75A - 3300Lux @ 1 meter .
Med - 0.29A - 1200Lux
Lo - 0.11A - 500Lux
WadeF
Perkasie, PA
So no one knows what light is producing that beam? No fun! :p
I'll give the beam 40 out of 50.
StandardBattery
MA
How about a shot of the actual emitter/reflector. I'm thinking you don't have a CREE XR-E there... well at least not one before SSC got a hold of it.
