I'm a K9 officer and want to get a light that is light but bright and lasts. It would be for searching areas as well as blinding suspects. I have a jet beam 1000 lumen and its good but was wondering what would be brighter and about the same weight or maybe heavier.
there is no portable searchlight to throw a beam 3-5 miles, even maxabeam doesn't throw as far. the most you can get up to 1000m, and for long rage hid is still better than led. we would be able to help more if you tell us $$$$ limit
I have used different models of Wiseled for SAR work for several years now and can recommend their latest Tactical NG. It packs 3300 Lumen of no nonsense Lumens. Five programmable output levels and a blinding strobe. Only possible drawback may be its proprietary non removable batterypack. I had mine customized by the manufacturer to 5000 Lumen ,the same as their Wisedive models. Overtemperature does not seem to be a problem thanks to their Ramflow system. www.wiseled.com
Olight X6 is the one to get for your line of work, and can be purchased for around $463.01. Checkout this Youtube video: http://www.youtube.com/watch?v=lb8sJJ34HOQ
The TM26 costs MORE than the RC40?Echo154,
Our K9 group are interested new lights also,
Is there a price limit?
In Europe, the TK75 is below the Euro200,
RC40 is just above Euro300,
The TM26 just below Euro400,
But those Wiseled's are above Euro700 !!
I have to say, if tracking through brush and wooded area, the small size of the TM26, PLUS its wall-of-light makes it a REALLY great light. The throwers are going to be for greater distances. The 4x,xxx candela, 3,500 lumen TM26 will throw far enough to spot a dog or human at about 150-200 yards (depending on the user's night sight of course). The throwers will be better for longer ranges.TM-26 and never look back.
The X6 light itself is not overly bulky or heavy compared to an RC40 for example. The belt mounted battery pack makes it easier to carry and folks tend to not notice it after a while. The connecting cord may be a nuisance in thick brush though.The X6 is a bit on the bulky side, and there's an exterior battery pack with a cord between them....counter to the specified request to control size/weight.
Since we still don't know if the use will involve extremely long lines of sight, or broad fields or warehouse interiors, etc, or not, we don't know if the best light for the task will light up 3 football fields at the same time, or, just the field goal 1/2 mile away, etc.
Good points, however, in foggy conditions, visibility is going to be poor anyway regardless. Under those conditions, simply using a lower brightness helps.i would suggest to try those lights in foggy conditions, cuz cold leds with wide beam and spill, will light up air in front of you, water droplets in the air, reflect light as mirrors, and limit your view. i have few such lights with small reflectors, and bright leds, in fog they are all useless, only hotwire, or hid with 2700k bulb, that have very little to no spill is useful in fog. warm leds would work as well in tigh,t no spil beam, but i don't have those. can't even think of one.
