2x CR2
I've got a little Coleman that takes 2 X CR2, it looks like a protected 14500 will fit with a little wiggle room at the sides. I've heard they have a pair of resistors in the head, I figured I could pull those and direct drive it.
if its the coleman I think of, its true, its just an XR-E with ~4 ohms in series. It might not take so nicely to changing to rcr2's but a lower resistor (or maybe dd) and a AA sized lithium secondary would definitely work.
http://www.cpfmarketplace.com/mp/showthread.php?t=230876
AW lists his 15266 size batteries as RCR2, but you can get protected 14500's with slightly more then double the capacity, that should fit in the same spot as 2 CR2's
