2x Cree, bFlex, 3x 18650 Road-bike Lights
Andres
Adelaide, Australia
Hi all - I've been lurking around CPF for a while but thought I would sign up and start a thread so that I could get some of the collective experience of CPF to cast a critical eye over my road bike lighting design.
:wave:
Just as a bit of background which hopefully justifies some of my design criteria;
I've been interested in torches every since I was given a Minimag many years ago. Obviously things have come a long way since then, and still have a long way to go!(i.e. a multimode, regulated, 1xAA, focusable, tailstanding, forward clicky light in a nice body!!!) But I digress...
Lately I have been using a MTE 5-Mode 100 lumen rebel, 1AA light zip-tied to my helmet as forward lighting. This has been pretty good for commuting, but obviously there is potential to be a lot better. A lack of output, and non-helmet mount are my main reasons to upgrade.
I understand a helmet mount 'spotlight' is handy (essential?) for MTB, but for road and commuting, I find there is usually enough 'other' lighting to see what's around, but I need a much brighter light to see the big potholes / branches far ahead to give ample time to avoid them. Furthmore the angle of my head changes substially from when I'm rising with my hands in the trops to when sitting back on the top bar. Unfortunately the angle tends to work the 'wrong way' too, with the torch pointing at my front wheel when going faster in the drops, and way of in the distance when peddling slowly and sitting back.
Having seen the output of my (from all reports- very underdriven) Romisen RC-T5 4xCree light up the street very well, I believe I should be able to get more than enough light out of 2 Q5 Cree emitters, driven at well under 1000mA for all but the darkest, fastest sections of road.
The lighting system will be attached to my Learsport 8500 roadie. It's a nice cheapish bike with Ultergra componentry and Mavic wheels. I use it both as a commuter 3-4 days a week and also for longer 'pleasure' rides.
I have decided the lighting should be left on the bike 99% of the time, although the batteries will not. I believe this will allow for a stronger mounting method which will be more resiliant to both vibrtions and potential theft (although rarely will the bike be in a location where theft of the lights could occur).
I will go into more details, hopefully with some CAD images, of the mounting method later, but first I need to make sure I have the electrical side of things correct;
The plan thus far is to have:
3x 18650 Li-ion batteries connected in series, to a bFlex controller, connected to 2x Q5 Crees in series.
From what I've read, the Q5s can need up to almost 4 volts at the higher currents, and taking into account some driver lossses, 3x3.7=11.1V of voltage from the batteries should mean there's always enough juice to prevent the bFlex from having to fall back to direct drive, and also allowing a decent runtime. While very crude, and doesn't take into account the diminishing effeciency at higher current etc, I was able to get over 3 hours from my RC-T5 on high from 2x18650 batteries pushing 4xCrees, so I figure as a very rough estiamte it is safe to assume I will get over 3 hours from the 3x18650 driving 2x Q5s at a sensible level. If anyone thinks that this is unlikely, please say, as a 'safe' 3 hours is my aim for running at arund 750mA. Any longer than that and I'm sure I'll either be at my destination, or happy to take a 5 minute break to switch batteries. Furthermore, that allows for 5, 30 minute commutes, meaning the batteries could be recharged roughly once a week.
The other part I'm looking for a little though on, is switching for the bFlex controller. From reading other threads and the manual, I believe it requires a momentary action switch, but does not need to handle the full power of the lights, as it is only a 'signal' switch? As such, I thought it would be a very elegant solution to use the momentary switches deisgned into the "Flight Deck" Simano shifters on my bike. These are actually designed to control a matching Shimano cycling computer, but from all reports, the computers aren't too great, and regardless, I have a nice Sigma computer I'm quite happy with as it is.
Is there any forseeable issue with this electrical design, or anything significant I have overlooked?
PS Sorry about the essay length, the last two paragraphs are the importnt ones though! :whistle:
On the runtime question.
If your li-ion cells are 2000 mAHr, you have 3 x 3.7 x 2 = 22 watt.hours of capacity (roughly).
Running 2 Cree at 750mA you have 3.7 x 2 x 0.75 = 5.5 Watts at the LEDs. Assuming 90% efficiency we have 5.5 / 0.9 = 6.2 Watts input power.
So, runtime would be nominally 22 / 6.2 = 3.5 hours.
For the switch, yes, a momentary action switch (normally open) is required. Current through the switch is <1mA since it is just a control input to the uController.
cheers,
george.
Thanks George :thumbsup: shoulda been able to work the run-time out myself. Oops. I reckon the Li-Ions are either 2200 or 2400 mAh, so that should be great for running at 500/750mA most of the time but with a bit of room for the occasional 1000mA burst. The 3 hours 'minimum' should be a breeze.
Good to hear the switch is very low current. I'd imagine the little switch in the shifter should be able to handle that easy... Although I still actually have to buy the swtich seperately - roughly $30 :mecry:But the 'integration' will be worth it, if it works!
What gauge wire do people use between the driver and the emitters, if there's going to be about 1m total length? (i.e. .5m to the furthest emitter). I assume the wiring to the switch can be very thin.
Have had a few bits and pieces arrive in the mail of late. Thanks to Cutter Electronics, very prompt! (And DX wasn't too shabby either this time). I realise most would have seen what these parts look like before, but for me images make it much easier to understand.
3 Q5 on Stars from DX. Apparently these are 'premium' stars? Not sure what makes them better, if anything? Maybe thicker material? I bought 3 as they were so cheap (~$7), and allowed me to :poof: one.
2 Carclo Optics and Holders. I got the 8.4 degree and I think the other is a 10 degree. Although it might have been the 20 degree. I'll see how these go once it's complete and then look into trying different angles. These were about $8ish.
One side of the bFlex driver/controller/magic PCB.
Now I'm having a bit of trouble working out how the optics holder is meant to interface with the LED. As you can see below, the cutout on the bottom is pretty square in shape, whereas the rectangular section surrounding the emitter on the star is more rectangular.
I can't get the holder to 'clip' onto the LED, although I haven't really pushed hard. As you can see, if it doesn't 'clip' on, there's quite a gap between the top of the actual LED dome and the bottom of the lens. I'm guessing the LED is meant to get right up inside the optic like in the second image below.
I'm wondering if a viable solution would be to cut out more of the lens holder and then just glue the lens holder to the star? My only worry is that the distance between the led and the lens is obviously quite critical for focusing. I think it may require some experimenting to work out where the lens is designed to sit with respect to the emitter.
I'm still in the middle of final year engineering exams, so progress will be slow for another week or so. At this rate winter (in the southern hemisphere) will have passed by the time they are finished. :laughing:
Quick CAD Model
A rather crude CAD image of how I'm envisaging mounting the lights. Obviously the drawing is somewhat 'abbreviated' as I didn't bother with doing both side of the handlebars. It isn't terribly accurate, the angles were done by eye, but they are not crucial to the design as the actual light will be completely adjustable in rotating both vertically and horizontally.
You can see my handlebars are kinda oddly shaped, not the tradational curve.
Hi Andres :welcome:
Yes that holder isn't right. I have some spares if you want.
I didn't like the Carclos that much. The 10.4deg one (10200) was the nicest beam -good for flood.
The newest ones from Cutter look real good. Just tried the 40deg one tonite -nice even beam.
Do you think your lights might be in a bit of a vulnerable posi on the end of you bars?
If you solder direct on to the emitter you won't have to chop the holders.
Switch wires can be thin ,24AWG is fine ,20AWG is about the biggest you can get in the bFlex holes (not tinned). You are usually better keeping the LEDs as close to the driver as possible,but doing it the way you are,20AWG will be fine.
PM with your addy if you want the holders.
Cheers
Dom
Cheers
Dom
The location on the handlebars was chosen after playing with a torch and was about the only spot I could find that wouldn't result in the light reflecting on something mounted to the bike (i.e. the cables for the shifters) and dazzling me. I guess they are kinda vulnerable in a crash, but they should be relatively sturdy, and obviously being DIY, rebuildable.
The location of the bFlex (and batteries) is still to be decided, but I will take your suggestions into account.
I'd love the correct holders! I'll PM you my address now :grin2:
