whiteoakjoe
If I can run a light off of 2x16340's I should with longer tube be able to run 2x18650's with the same head, right? The light will get the same voltage correct? or is there another issue that I'm not seeing?
Thanks HKJ, that's the answer I was hoping for. I thought that was right but never did see that spelled out for me. Only voltage numbers were quoted so I assumed that's all I needed to know, but its easier to ask before something goes (POP) and won't come on anymore. I think since I want a warm white light around 200 to 300lm with flood beam I should be OK for heat sink. not looking for a high power light just long runtimes. Trevtrain I'm using a surefire 6P and building a light, was going to get a bored 9P body to use with the head and pill (Nailbender or Malkoff maybe a Nachia 219) that can take 9v input. But all I saw was them running on 2 16340's.
