3 cell Lipo Questions
atstodd
Hi All,
I have a Flightmax 5000mAh 3S1P lipo that i bought about 6-7 months ago. It sat in its box till about 2 months ago when i decided to balance charge it in anticipation of finishing my bicycle light. It took FOREVER to balance charge. about 10 hours maybe more. I would charge it for about 2 hours a day when i had the time to monitor it. One of the cells was a few tenths of a volt lower than the other two but slowly came up. The charger is a Turnigy Accucel-6.
I finished my light tonight and took it for a test ride of a little over an hour. Its a single SSC P7 emmitter running at about 2.8A. Before the ride the battery voltage was 12.05V and after it was 11.69V. I decided to measure each cell to check the balance and got 3.97, 3.96, and 3.75.
The 3.75 worries me a bit, but I have almost no experience with Lipos. Is this bad or normal?
That is definately not normal, having a weaker cell is definately a dangerous situation should it have been discharged more.
Try charging the battery and record the off-charger voltage (make sure they are all the same). Let it sit for a couple days and see what the voltages are like.
I will charge it up again. I should wait about 30min to check the voltage after charging correct? Also this battery is rated at 15C so I am not really stressing it at all as far as discharge rate. Does that matter?
Thanks!
I would give it a day or two, it's not likely to show much difference within 30 mins.
You should be fine, lithium-based batteries are capable of delivering high currents without issue.
Looks like some of the posts were lost. Anyway, I removed the bad cell after one of you mentioned the balance charge was taking too long. Now I have an 8.4v lipo that should run for a little over 3 hours. What should I do with the bad cell?
Actually, there is an easy and safe way to neutralize the battery (or cell in your case) for disposal in regular garbage. Unlike most other batteries they are evironmentally safe .
http://www.rctoys.com/pr/2007/07/06/safely-dispose-of-lithium-polymer-lipo-lipoly-battery-packs/
Basically, the long and short of it is you should preferably start with a discharged battery and submerse it in a plastic container (with lid) filled with a salt water mixture (1/2 cup salt per 1 gallon water) for at least 2 weeks. Then its good to go.
