TOOCOOL
So where are the reviews and beamshots what ya'll waiting for :lolsign:
tkflash1 said:Hi, Harbor freight has Gordon flashlight with 3 watt luxeon star in it that takes 3 d batteries and has a reflector that is very close to the Dorcy 3D 1 Watt flashlights. I picked one up and it is very bright with a tight hot spot. Item number is 95297. The quality on the one i got seems as good or better than the dorcy 1 watt ones. Looks like it would be easy to mod. As bright as this one is i may leave it alone.
martytoo said:Flash Crazy,
Do you have to do any soldering to make this switch?
I have not done any successful mods.
Thanks.
Handlobraesing said:So.. this is the commercially made version of what I made. I made a Dorcy Super 1W into 3W by bypassing the resistor and doing direct drive pushing around 1.4A w/ fresh batteries.
ace0001a said:At The Sandwich Shoppe, they have a few Downboy models, but it looks like they're out of stock on the DB1000. They do show that they have a couple DB917s in stock. You probably can't see the difference between the two.Thanks, Ace! I think I might do that. One question though....on the SS website they have a "calculator" that helps you to choose the right board. It's saying that if you're using a 1 or 3 watt Luxeon, and have a V in of 4.5-6.0 V, to go with a Wizard board. For 6.0V input and over, it says to use the Downboy...but on the Downboy specs is says it has a minium input of 3.0V. I guess as long as Vin is more than Vf it'll be fine....any thoughts?
FlashCrazy said:Thanks, Ace! I think I might do that. One question though....on the SS website they have a "calculator" that helps you to choose the right board. It's saying that if you're using a 1 or 3 watt Luxeon, and have a V in of 4.5-6.0 V, to go with a Wizard board. For 6.0V input and over, it says to use the Downboy...but on the Downboy specs is says it has a minium input of 3.0V. I guess as long as Vin is more than Vf it'll be fine....any thoughts?
lowatts said:Picked up the 3D light tonight. Definitely really bright with fresh cells, will have to try it out with my AA NiMH cells in D adapters to see how bright and how long it goes with them. I'm a newbie with LED lights so not too hard to impress right now LOL. Only seen pics of what good lights can do.
Had to pay $24.99 though as at my store these were "new" items, so no $19 deal for me.
Thanks for the heads up, but I'm actually going to try the single cell adapters, to make the AA the same size as the D, not the multi AA cell holders.FlashCrazy said:Nooo...don't do it! Hope you haven't already. These lights are direct drive. Using your adapters, you'd have about about 11 volts...the LED will burn out so fast you probably won't even see it flash!
