Just as an update; I've had the chance to test several other puke/pea green Luxeons, and all of them seem to be of lower internal resistance than the first one. The first one I moded with just seems to be a fluke. These others require either a 1 ohm or 2 ohm resistor to keep current under 700ma with fresh batteries.
I know that sounds like a lot of current, but the Luxeons don't get hot when mounted on the heatsink, and the current falls fairly fast (few minutes) to 600-650ma, and 10 minutes later is usualy in the 500 - 550ma range. This is using brand new D cell Energizers (average 'new' voltage 1.57V); different batteries may get different results.
The original 'jolly green giant' flashlight with the puke green Luxeon has been run for 48hrs at which time it was still drawing about 70ma, with cell voltages around 1.1V. Still bright enough to be useful, and casts a visible spot at least 50ft.
