big beam
Has anyone done a mod with the 3W blaster.I looked at voltage and amps today and it might work.Don't know about the lens?
big beam said:I just took mine apart and there is a rivet connecting the - part of the LED to the heat sink and a wire to the+ side of the LED.I'd have to drill out the rivet to remove it.
DON
I'd like to know what reflector would produce the absolutely, positively, tightest beam with a P4 in a Blaster head.Minjin said:We really need to figure out a reflector replacement for that optic...
Minjin said:We really need to figure out a reflector replacement for that optic. There's gotta be some el cheapo walmart Rayovac reflector we can use.
My CREE replacement went easy as cake though I almost wish I hadn't put the resistor back in.
Sub_Umbra said:I'd like to know what reflector would produce the absolutely, positively, tightest beam with a P4 in a Blaster head.
Wayne says that the window is 35mm x 2mm. I wrote flashlightlens.com a few weeks ago about the possibility of a Blaster UCL kit complete with the correct O-ring. I've got to get back to him and see what he came up with.
