idleprocess
QUICK SPECS
- Light source LED - Luxeon III
- Type medium-large flashlight
- Switch Momentary/latching clicky
- Operation dual-mode
- Operational sequence Momentary - on | off
- Driver Direct/resistored
- Power source 3x C
Alkalines OK
Rechargables OK
Lithiums (1.7V) will work with AA-C adaptors OK
- Focus Variable
- Beam Laser-tight spot to ring-y mag flood
- Construction Anodized aluminum
- Environmental
Water resistance: Waterproof (not for diving)
Shock resistance: Excellent
Crush resistance: Excellent
- Availability CPF member 3rd_Shift, should he ever decide to offer these for sale
PHOTOS
FLat View
Perspective View
The business end
Emitter/heatsink detail
Beamshot at ~15"
Test scene beamshot at ~15'
Test scene with florescent lighting
(Snide) COMMENTS
- Well-executed direct-drive Luxeon III mag mod
- Astonishing output - more than most would suspect from a 3x C light
- Marvelous Luxeon tint
- Light is a throw monster that can project a ~5' (1.5m) hotspot at ~1500' (450m) visible in bright moonlight
- Light works well in "candle mode" due to absent reflector cam
- Focusing is precise if tedius - head movement determines focus, not pedestal cam
- Direct-drive limits power options - recommend use of alkaline cells
- Suggested use: all-around medium-large flashlight
