(519a, xpl-hi, xpg3). ...very little lumens.
What should I try next?
the things that increase lumens are
1. Low CRI (that rules out the 519a)
2. Cool White color temperature, look for options above 5000K, for example this
7500K or 6500K XP-G3
unfortunately, there is a trade off between more lumens quantity, vs more color quality
the LEDs with the most lumens have ugly green tint, harsh blue color temperature, and poor color rendering (especially in Red)
> They're great at 3.7v but my flashlight only gives me 3v
the Voltage of the LED is not the primary factor controling its brightness
it is normal that the flashlight gives 3V to the LED.. that is not what makes them less bright. Fenix decided how much current (Amps, not Volts), to send to each LED in your light. They chose a Power level (Watts), they think is bright enough for the role of each LED, while still retaining acceptable runtime. You can not change any of those factors.
you can change the LED, but there are tradeoffs.
LEDs become less bright when the underlying blue LED gets coated with a phosphor layer..
to make an LED, less green tinted, less blue color temperature, and give better color rendering, requires increasing phosphor density, at the expense of less light transmission..
Maybe this is a perfect excuse to search for a new light you might want to buy ;-)
