Lumenous H
- Joined
- Jun 14, 2009
- Messages
- 3
Hello all, I'm a long time lurker first time poster.
I've been working as a security guard for 3 years now and I'm building myself a new flashlight for my job. Due to the nature of my job, it needs to be Mag-sized, light weight and have a run time upwards of two hours between charges. Because I'm also compensating for my lack of... I'm going to be a lumen-whore about it too.
I'm planning to make the new torch run on two 10ah, 3.2v LiFePO4s (I don't touch Lithium Ion). In parallel that will be 20ah at a nominal 3.2v. I can do a low voltage cut off circuit easily enough, I just need a driver/regulator that will enable me to run the LEDs.
The plan is to run 4 MC-Es, all in parallel. If you could bear with me whilst I yak about the throw patterns, so you may better understand my circuitry needs; one LED will be a warm white 'flood' beam of about 27 degrees, two will be cool white 'power' beams of about 10 degrees and one will be my 2 degree 'spot' beam. There will be a setting switch to dictate which LEDs will be turned on and I'm also after a high/low power switch.
Does anyone know of a driver that can input 2.7-3.5v and output two selectable states, both ~300ma and ~700ma? And for this driver to be able to output those states 16+ times? I could use 4 times 4-output drivers, but can't really go much beyond that.
I appreciate any help I can get in this respect, and I know there are many experienced modders on these boards.
