gnef said:
This is the seller that I bought 100 40k LEDs from recently.
It is irritating that I find out I paid a little over $12 more for the same thing that the OP posted. :rant:
In any case, I bought them to replace the LED's in a cheap hybrid lantern (non regulated) that I bought on eBay.
Here is a link to an eBay auction that shows the type of lantern I am talking about:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=8738827457
It worked fine in the beginning, but eventually, all of the original LED's were either weak, flickering, or dead. I put in all new LED's (and sockets, to make future replacements very simple), and it is now brighter than when I first bought it.
Side note:
Here are links to some "sockets", just in case anyone needs these:
http://www.goldmine-elec-products.com/prodinfo.asp?number=G12996
http://www.allelectronics.com/cgi-bin/category.cgi?category=192&item=SIP-30&type=store
http://www.allelectronics.com/cgi-bin/category.cgi?category=192&item=SIP-81&type=store
I am kind of worried though. I feel that the LEDs may be overdriven, and may also burn out like the originals did.
The lantern uses 4 D cells in a holder, but you could also take out the holder, and use a 6 volt lantern battery instead (which is what I did, although the auction didn't mention you could do that). It has 10 LEDs connected in parallel, with a 2 ohm resistor for each LED.
Is this the right size resistor? Or should it be higher?
edit:
Here is a pic of the bag that the LEDs came in:
NOTE:
The 40K LEDs I recieved were definitely brighter than the old LEDs, but they had a slight blue hotspot, with a slight green ring around it.
And here is the link to their LEDs.
NOTE: I could not find the model # of these LEDs in their list
http://www.led-center.com/led_lamps.htm
