Most lumens for the money
davidra
....in a 3x123 light? Limited budget but need something really bright...
Rothrandir
US
pila g3 is a great light for the money!
look here
maybe not the very brightest, but it's a great and inexpensive light, and can use pila li-ions! /ubbthreads/images/graemlins/grin.gif
revolvergeek
Louisiana
Cheapest thing would be a 2-c cell Maglite running 3 x 123s and a 5-cell bulb. Might be a little bigger than you are looking for, but it is pretty cheap and bright.
JasonC8301
NYC
I would agree with the Maglite 2C running 3 CR 123's and a KPR 112 bulb. $14.95 for Mag 2C (how much I paid), a homemade 3X CR123 to 2C battery holder (PVC pipe and two fat rubberbands from Home Depot) $4, a KPR 112 bulb, $1.25.
For around $20 you got you're self a cheap and bright flashlight (I would say (ok guess) around 175 or so if my Tigerlight is 285.) You are driving the KPR112 really hard so get a few....dozen extra if you use it a lot.
The top two are Mag 2C running a KPR 112 with 3 X CR123's. The left one is a Orange Peel'd Perfect Mag Reflector, the right is the stock reflector. (You lose some throw with a OP PMR over stock, but it makes the beam a heck of a lot nicer.)
The bottom left is a SF E2e which doesn't throw as much as the Mag 2C but has the SF perfect beam and now runs for $95 new.
The bottom left is a Tigerlight.
pedalinbob
Michigan
the 2c mag/kpr112/3x123 mod is crazy bright--and sooo inexpensive.
yeah, i am a bit concerned about bulb life, but want to try a 6-cell xenon-star. it will give up some brightness, but result in a more reliable light.
of course...i havent changed it yet.
why? i love seeing the reactions to my little super bright monster.
heck, im thinking about going 12v!!!
Bob
jtice
West Virginia
Build a LuxIII,,, or 5W, 2C mag.
With 3x123.
LuxIII use a DB1000,
5W, you can direct drive, or get more flat runtime from a DB1000,
CalgaryGuy
Alberta, Canada
Yeah, I plan to mod my mag 2c later, does anyone knows if I can get a turquoise 5 watt LED? I want raw power /ubbthreads/images/graemlins/wink.gif
JasonC8301
NYC
I tried a 5 cell Xenon Magnum Star in the Mag 2C mod running 3 X CR123 and instant flash bulb when I clicked the switch.
I ran a 6 cell Xenon Magnum Star for a while then switched over the KPR112 because it was just a tiny bit brighter.
I have not tried the White Star bulbs though (the ones that come in a 2 pack.)
raggie33
*the raggedier*
do ya need to change any thing else when ya switch to a kr112 in a mag2 d other then use 3 123a,s
JasonC8301
NYC
raggie33,
Just unscrew the head/bezel/ then change the bulb. Then reassemble.
In a Mag 2D you have two options. You may run 3 X CR123's or run 6 X AA in a 3 to D battery holder (rechargables of course.)
paulr
What's the point of using a M*g 2C instead of some generic 2C light? I don't think the generic 2C is more likely to melt or anything like that. I got a KPR118 bulb at Radio Shack that I've been wanting to try with three 123's.
tater_salad
[ QUOTE ]
look here
[/ QUOTE ]
I have one of these on the way. CPF member Madecov can attest to the lamps durability and puts out a better beam than SF.
The Streamlight TL3 would be my next choice, or first if I needed throw.
