i plan to run four xm-ls in series from one 12v SLA, with pwm control 0-5A (theyll be run at 1A mostly). Ive read a
heap, but not what to do when the combined LED voltage drop (plus driver) equals the battery voltage, or at least
will be just above/below depending on battery charge and odd voltage drops? I dont really want to run SLAs in series, if Im going to carry two
of those things I want longer runtimes. Size or diy is not an issue but cost is however. The main thing is brightness
control, which ideally could be set between adjustable presets, remotely if possible if anyone knows of such a thing.
The leds will be on MCPCBs for now, fanned al sink smaller than half a brick, i shouldnt be asking 70w
of it for more than a few seconds at a time. And while im here i might as well ask, how can the wires on in leds be
so small for the amps?
i had another profile from a year ago when i first started to think about this light, forgot email/pass tho so start from 0 again.
thanks all.
thanks all.
