4x 4/5 SubC inside Mag2D will it fit?
rizky_p
13th Colony
I have done some calculation that 4x 4/5 Sub-C(Elite) will fit inside Mag 2D is that correct?
It will replace a 2x LiFePo4 18650 battery currently powering a single P7 since the 4/5 SubC battery will have better runtime and efficiency with 7135 driver which i currently using.
Thanks.
Thanks.
I'm sure it would fit -- 2 unprotected 18650s just fit in a 2C (so 130mm), and the 2D should be 20mm longer internally. Even if the 4/5sC were 35mm each, 4 would only be 140mm, so you'd have at least 10mm for spring.
now i remember darkzero's DD Mag2C running of 3x 4/5SC.
But i'll be using 4x 4/5SC+ 10x7135 IC to run P7 at 3.5A to get flatter curve instead of the direct drive as per darkzero's solution.
thanks guys, i'll order the batteries soon. :)
