hmm, looking at the P7 specs it's typical voltage is 3.6 and max is 4.2 with a with 2800ma forward current, so I think it should be fine without anything???
3.6-4.2V is the RANGE of possible Vfs that a P7 could be. It is not the range that you can operate any single die at. Some will REQUIRE 4.2V to achieve 2.8A forward current, while others will only require 3.6V, they probably average somewhere around 3.9V. Taking P7 with a Vf of
[email protected], and pushing 4.1V into it, could very likely push it up around 4 amps or more. If it were a 3.6V Vf LED, and you hit it with 4.0V, it would probably jump to around 6 amps.
LEDs have a very narrow voltage "range" that they can be operated within, and there are inconsistencies from batch to batch in the manufacturing process, this is why they usually require current regulation in the design. The exception to the current regulation "rule," is if you have a power source that happens to come to an equilibrium with the load and Vf of the LED chosen, sometimes with the assistance of a low value resistor. Kind of like taking 3 AAA cells and direct driving a regular LED, like a Luxeon III or Cree Xlamp or Seoul P4, the cells end up sagging under the load of the LED and coming to an ideal equilibrium with the LED. It can be assumed that most alkaline and consumer oriented rechargeable AAA cells will suffer a fair amount of sag under the ~500mA-1A load of a single die LED, enough that you never have to worry about overdriving, but taking that same 3xAAA light, and running it on a single larger Li-Ion cell, or 3AA cells instead, can have the undesired side effect of substantial overdrive since the larger more capable cells hold a higher than expected voltage under the load of the LED, capable of pushing it well into overdrive/overheating territory. Switching to a 3AA or 1xli-ion design would require a modification to the resistance in the path to the LED, either in the form of a simple resistor or regulator. My feeling is that the same considerations need to be taken into account when you add more cells in series to a direct driven P7 setup....
Personally, I think it would warrant at least some testing to be sure, start with 1 fully charged 18650 and test the current on high, then try 2, then 3, and see what's happening. There's a very good chance that you'll be under 2.8A on 1 cell, but this depends on the Vf of the P7 in your particular unit. There's always the possibility that you could have an unusually high Vf LED that actually NEEDS 4 cells to actually HIT 2.8A. I would personally assume that they would choose LEDs for the 1 cell design that at least semi-complement the behavior of a single cell under that load.
Eric
