Hi,
I have the SUPERNIGHT (TM) 5M 16.4ft 5050 RGB 150led Waterproof Dream Beautiful Colors 6803 IC LED Strip Light (SKU:EBT073) and I am controlling it with the SUPERNIGHT (TM) 6803 RF Controller 133 Change for Dream Beautiful Colors Chasing 5050 RGB LED Strip (SKU:EBT074).
The controller comes with a cable that connects the light strip to the controller and it is around 8 inches long. I need a longer run between the controller and the light strip, so I purchased the SUPERNIGHT 10M 4-pin RGB LED Strip Extension Cable Line Cord for 5050 3528 5630 Flexible RGB LED Strip (SKU:EBT502)
The problem is the lights wont work when I have the extension cable in line. They are just dim or they are full bright on one color and the controller does nothing to change them. I have plugged in a power source (12 volts – 6 amps) into both the controller and the light strip itself and I get the same results.
I managed to get it working as designed once I shortened the extension cable to 4 feet or less. Any more than 4 feet, and the lights/controller cease to function. I have tried this with multiple controllers and light strips with the same results so I have ruled out faulty equipment.
does anyone know how to make the system work with a cable between the controller and strip that is longer than 4 feet? I need the run to be between 10-15 feet.
Thanks!!
Thanks!!
