There is usually no binning of the LEDs in the cheaper lights. They are sold by how many LEDs are in a torch. Instead of P3>P4>Q2>Q4>Q5>R2 they go 1LED>9LED>21LED>100LED>128LED.
Ocasionally they will specify the LED such as 22000mcd. If the package says Nichia LEDs then you probably have a Nichia BS. If it says 2X BRIGHTER LED then you probably have a Nichia CS.
the only problem with just knowing if it was 1 led or 128, is that still doesn't tell me if it's efficent.
can we buy any 5mm led lights and know which led's they have in them.
i wouldn't mind an emergency light but i want as close to 100 lumens/watt as i can?
anyone know much about the bins of these leds?
how many manufacturers of 5mm leds are there?
The only manufacturer of 5mm LED torches that will tell you the exact model of LED is Arc. But with a tiny AAA battery the runtime is in the 5 hour range. Peak says "snow" then refuses to tell where the snow LEDs come from.
The SMJLED PR from Lighthound (the ones I got anyway) uses ARCmania's SMJLED. From jtr1962's thread (see link below):
SMJLED 4-die 5mm white (acquired July 2006)
Color temperature is about 6500K to 7000K. Beam angle is fairly wide (31.6°) so the intensity is low, reaching only 7,100 mcd at 20 mA. Efficiency at 20 mA is 87.8 lm/W which is a new record. Once again, note that since each die is only receiving 5 mA this number isn't as good as it appears at first glance. Again, this LED shines at higher currents. Once past 20 mA it surpasses every 5mm white LED tested to date in efficiency. At 100 mA efficiency is 57.2 lm/W. As expected, forward voltage is very low compared to other 5mm whites since each die is only getting 1/4 of the current. Lumen output far exceeds any 5mm LED tested to date, reaching 17.67 lumens at 100 mA. While these numbers are great, remember that at 100 mA each die is only getting 25 mA. Just for comparison purposes four Jeled 50,000 mcd whites each running at 25 mA would output 26.5 lumens at an efficiency of 76.7 lm/W. Basically, this means that the dies used in the SMJLED are decent, but not the best available.
Please note the SMJLED2 in Sandwich Shoppe's SS PR is a completely different LED.
jtr1962 tries to keep track of the various LEDs available in North America here:
http://www.candlepowerforums.com/vb/showthread.php?t=89607
Chimo also did some LED comparisons
http://www.candlepowerforums.com/vb/showthread.php?t=84890
http://candlepowerforums.com/vb/showthread.php?t=89759
