VidPro
I will try and keep this simple
when rating a 5mm LED there is ANGLE 5* 20* 60*
and angle AT a specific MCD rating can be all the difference in the world.
if i have a 60* that rates 6000 it might put out as much overall light at a 5* rated for 20000
(correct any of that if its wrong)
so there is angle, THEN there is "efficiency"
having 2 LEDS of the same Angle binned for less or more MCD.
so now the questions
when binned for output, is it possible that (basically) the light depending on how its DRIVEN would be no different than the others.
like
if they test it at a specific current, or voltage, and the place that it is being meterd happens to read higher.
OR
are the brighter at the supposed same specs, ACTUALLY more efficient, and actually put out more overall light.
The project:
assemble 100 5mm try to get the most light for the least power, without any concideration for how bright it is in ONE spot .
will wizz bang 22000 LEDs VS 12000 leds make a whole room 2x brighter when using the exact same Power overall?
like
OR
The project:
